Discuss Tiling pleasure beach fun house in the Canada Tile Advice area at TilersForums.com.
wickers
Hello,
RE: JOB AT THE FUN HOUSE
This is my first time on this forum. I am not a tiler, more of a general builder. I have been asked to tile a friends bathroom. He has plastered the walls himself. There is not one level wall (the walls have been boarded and skimmed). The bath runs along the back wall with a window above it. The bath just fits into the width of the room. The slope of the back wall is so bad that there is a difference of 2" from the top of the window reveal to the bottom of the reveal !! There is also a plumb difference of about 3" in the side walls from floor to ceiling.
He is adament that the new plaster stays in place. The best I could offer was to cover the walls with hardiebacker/aquapanel etc (level) and tile from there. He won't have it. He wants me to tile on the walls as is (he's paying so I can't disagree too much).
Any ideas about choice of tiles (large, mosaic etc)? Any tricks that could hide these deviations in level ? Or will I just have to cut lots of funny shaped tiles?
Thanks for any advice.
Wickers
SJPurdy
So what is the problem? This is surely the normal standard of plastering in the UK. If each wall is flat (both ends of the wall and all points in-between lean into/out of the room by the same amount) then it can be tiled without a problem (other than matching joints at corners). It is when the left end of the wall leans into the room and the right side leans out then you have to bend the tiles.
wickers
Thanks for the reply. The trouble is that people see the tiling and not the wall behind it so I would get the blame for a bad job.
bugs183
Don't do it, sounds like a right bodge. It would be a nightmare for a tiler, let alone someone who doesn't do it for a living.
The window reveal will be a nightmare if the wall is on an angle, that's for starters, if the walls ar that much out of true you wouldn't keep the bond in the internal corners either, it will look awful.
Not worth the agro!
White Room
No it is'nt, any plasterer leaving work like that should hanging up his trowels or himself....
Reply to Tiling pleasure beach fun house in the Canada Tile Advice area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
    Votes: 6 4.7%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.7%
    Votes: 16 12.4%
    Votes: 31 24.0%
    Votes: 3 2.3%
    Votes: 2 1.6%
    Votes: 19 14.7%
    Votes: 18 14.0%
    Votes: 15 11.6%
    Votes: 6 4.7%
    Votes: 3 2.3%
    Votes: 2 1.6%
