Tiling Rates Per Square Meter - How much does tiling cost?
Dan
Admin
Staff member
Tiling Rates Per Square Meter / Per Day – How much do tilers charge?
I know this is a hard one to answer. But just as an approximate guide for those searching for how much a tiler costs, and landing on websites such as my builder who seem to be selling tilers for pennies, how much you been charging either day rate or per meter generally?
Perhaps if you could split your work between your fancy stuff, and your bread-winning stuff over the past year or so, then do that so we can see the difference.
And then perhaps price per floors and per walls? If different at all.
Just wanted to get the facts straight for those searching, as £150 per day or £20 per meter isn’t what I’d expect to pay anymore. It’s not the 90’s lol
Tilers replied to our thread here.
How Much Do Tilers Charge?
Is it per square meter or per job or per day rate?
It appears to be a bit of a post code lottery perhaps. So we thought we'd get a bit of a thread going to see what others charge and why.
How much do Tilers Charge?
Thank you. Already helping out there because both of those are above what is being told to customers on other websites. So keep them coming and I'll try and average it out near the end and update the first post to reflect that.
I'm £35/40 for general stuff obviously more for stone/natural but usually price a job as I see it. day work at £200 plus materials
I usually charge between £25 - £35 per m2 for labour only but it depends on the material and state of the floor or wall. If the tile is small and the pattern is complicated it changes again. We've charged as much as £55per m2 for 100x100 tiles. If you're working away the price needs to include your accommodation and money for food etc but that can vary depending on where you are (London is far more expensive) day rate is obviously less at home and depends on how many hours you do. I work on a day rate of £250 when I'm away and £200 at home but again it always varies. Hope that helps
Herefordshire area,usual ceramics and porcelains 28£m2(thicker than 10mm 30£m2),stones 35£m2,(thicker than 15mm - 40m2),mosaics 35-40£m2 ,if area is tricky (a lot of cuts I go for day rate -200£ , prep ,levelling etc also at day rate. Usually customer gets fixed cost for labour on quote and estimate for materials( if required)
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
