Discuss Tiling replacement NW2 London asap in the British & UK Tiling Forum area at TilersForums.com.
roopster
Hi,
I'm looking for an experienced tiler to replace five 600x300 porcelain tiles in a property in NW2 in London. Due to some poor quality plumbing work, the tiles under the sink (where the waste & valves are) and behind the shower valve have had to be removed and now need replacing, along with two access tiles on the bath panel, and another tile that has been chipped under the sink.
Hardi backer board has been used, so I'm not sure if the adhesive can be cleaned off, or if this needs to be cut out and replaced for the new tiles to be flush and level.
So it's a bit of a pain of a job & not particularly satisfying, but hopefully would be of interest to someone fairly local?
Please PM me if you are interested - I need the work doing asap!
Thanks for your help.
Reply to Tiling replacement NW2 London asap in the British & UK Tiling Forum area at TilersForums.com
Had wet system UFH installed on a concrete subfloor to the whole ground floor ie living room...
Posted a couple of times for advice a few weeks back, the outcome of which was to scrap my plan...
Trying to Get bathroom re tiled, had conflicting advice from a few tilers, I’m a total novice...
6K
Hi all, I’m hoping someone can help. in June 18 we had some tiles fitted to the kitchen and...
8K
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
