Discuss Tiling round door problem. in the UK Tiling Forum area at TilersForums.com.
A1P
Had a bathroom with walls in bad condition and totally out of alignment.Decided with the customer to have the walls completely boarded out with plasterboard sheets dot and dabbed.Job done well, all level.However I and customer were aware there would be a problem round door as door architrave very thin and board edge would overlap it by a noticable amount.Hoped to come up with some sort of edging although not happy about it.The problem is now worse as the door frame is well out of the vertical.I now have a protruding edge which tapers ARGH!!!There is so good solution but i would happy with suggestions to make the best of it.The customer doesnt want additional work to door.-cost.I thought maybe a hefty architrave might improve matters but not sure it would look good.
Colour Republic
I'm not sure this is possible. I never dot and dab a wall with a doorway in it for this very reason, nothing you can do easily is going to make it look natural.
If you must build the wall out then I would always do it in stud work so the recess is more pronounced and looks deliberate rather than trying to make up a small gap (but this can make a small room even smaller). The other option is to replace the door liner but the customer doesn't want the added cost so what are you to do?
Colour Republic
the only thing I can think of is to build up the edge of the door frame with a planed wood to a thickness of the dry wall and tile, once your've tiled then put the architrave around the frame which will overlap onto the tiles
That would work but the only problem is that the paintwork would crack on the joint once the door had been used a couple of times
Colour Republic
We remove the lining, Replace in MDF cut with a plunge saw so the MDF sits at the same level as the surface of the tile, Then new facings sit\on top of the tile....Looks a pro finish and no risk of cracking
Works easily on outward opening doors...Inward openings require a little more work
Are you suggesting replace the complete door liner with MDF? (I assume you use this material so you can cut to what every size you require) If so it would work but unfortunately hanging a door off MDF does have its problems 1) it is much harder to rebate a hinge in soft material like MDF and 2) Screws have a way of working them self’s lose from MDF when any sort of weight (such as a full sized door) is placed on them.
Not trying to argue with anybody here just putting a builder/decorator/joiners point of view across:thumbsup:
simhopper
Yes just the liner and not the frame
Router works well on MDF
Longer screws
Cost wise it takes approx 1hr, On a normal bathroom job that takes 80hrs this is nothing in achieving a good finish
Colour Republic
MDF eats router bits, but thats not the point and only minor
Longer screws
Sorry to disagree but longer screws won't always solve the problem, 9 times out of ten longer screws won't take hold of the substrate behind and if they do it is only paying lip service, the problem comes when the screws chew up the MDF in the first place, you might get away with it in the short term, even more so with a light weight door. But if I replace a door liner than I want to know that any door can be hung off it in the future. The bottom line is door liners are not made of MDF because of this reason and are not repairable
This point I agree with:thumbsup:
Again not trying to argue but if you're going to do something (which I don't think in this instance the customer is going to pay anyway) then I would always make sure my changes are future proof:thumbsup:
Colour Republic
I would just extend existing frame with some Batten cut to size on a ripsaw then screwed and glued and when dry sand back, that joint will not crack any paint the tiles will fall off first :yikes:
Ok I shut up in a minute:lol:
Again I disagree, it will crack. As I’m multi-trade I have to make sure that no part of my work falls down, or it's me sorting it out!
I often hear on here how another trade has messed something up only for you to be left with a problem to sort out, so it's only right that where possible you don't do the same.
What I will conceded is that adding a filler is probably the cheapest and easiest route and the side effects of hairline cracked paint with have to be accepted by the customer by way of saving money. The less of two evils as they say
I'll get off my box now:oops:
Reply to Tiling round door problem. in the UK Tiling Forum area at TilersForums.com
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Greetings All, appreciate the expertise existing in this forum. I am a home remodeler, not a...
5K
6K
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
