Discuss Tiling round door problem. in the British & UK Tiling Forum area at TilersForums.com.
A1P
Thanks for all the suggestions.this bathroom was always going to be a nightmare.I wont go into the 40 degree wall which joins at the other side of the door!!!! Any thoughts about any possible edging strips which would not be too horrendous-probably clutching at straws.I think I saw a recommendation for Genesis? products on a thread.Not hopeful.
N
Nardini
Much as I might have used MDF in the past as a panacea for all ills, in this case I would give the MDF a miss - certainly on the hinge side. Use white pine that has been (old age, forgot the word) aged/cured/matured/... ((What IS that word!)) and rout the edge to the final trim. That makes it look very professional (exhibition bodge trick) and the timber keeps some strength in the hinge fixing. Prime and paint and it will look a million dollars - but without the bill to go with it. If you need a stained wood look, use real wood - if you need mahogany, use mahogany, etc. Hope it helps to know how the master bodgers would do it! LOL!
Reply to Tiling round door problem. in the British & UK Tiling Forum area at TilersForums.com
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Greetings All, appreciate the expertise existing in this forum. I am a home remodeler, not a...
5K
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
5K
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
Hi Guys. I have my downstairs loo to tile. 2 walls are going to be studed out so no issues...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
