Discuss Tiling Software in the UK Tiling Forum area at TilersForums.com.
waterfd
Hi, I have been using TileGem software and have found it OK however it is limited to set tile sizes mainly inches that relate to metric and there is only the length measurement so for example a 600x300 tile is set up using 24" and using a brick pattern. This can be a problem if the tile does not match the width. So the plan is only an approximation of what it could look like. I have recently upgraded to Windows 7 and the program is not as reliable.
I saw a post recently the Sir Ramac was trying some software and did some examples for a question. Can you tell me what it is and if there is other software out there that will do the job.
I find showing the customer a visual representation works for me.
Rgds Des
Reply to Tiling Software in the UK Tiling Forum area at TilersForums.com
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Tiling Software
