Hello. I need to tile an indoor stairs, which trim can I use? Could be a normal aluminium L shape ? Any other suggestions I should have in mind for the job? The actual stairs are concrete. Thanks on advance!
Discuss Tiling stairs, which trim shoud i use . in the America Tile Forum / Advice Board area at TilersForums.com.
Hello. Are private, in a semi detached house. Back in spain I did a lot, but always with marble or tiles with bull nose, never with trims.what are the stairs used for, are they public or private ?
Thanks, I will give it a go,thats fine you can use a square edge trim (L shaped) or you could use a noseing trim
which goes over the top or some you fix first and tile up to it . Use the one you think will
look best, im sure your local tile store will have some options.
Thanks! I wasnt sure about it.thats fine you can use a square edge trim (L shaped) or you could use a noseing trim
Reply to Tiling stairs, which trim shoud i use . in the America Tile Forum / Advice Board area at TilersForums.com
