Tiling stairs, which trim shoud i use .
Hello. I need to tile an indoor stairs, which trim can I use? Could be a normal aluminium L shape ? Any other suggestions I should have in mind for the job? The actual stairs are concrete. Thanks on advance!
thats fine you can use a square edge trim (L shaped) or you could use a noseing trim
which goes over the top or some you fix first and tile up to it . Use the one you think will
look best, im sure your local tile store will have some options.
Thanks, I will give it a go,
Thanks! I wasnt sure about it.
Enrique volta,
Enrique volta,
Enrique volta,
Enrique volta,
