Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com.
Matty A
IMPORTANT CHANGES TO BS 5385-1 WALL AND FLOOR TILING​
Tiling Standards | BS 5385​
As part of the five-year review of British Standards and reflecting changes within the tiling industry since 2009 – BS 5385 Part 1: 2018 has now been published. One significant change made was to exclude the use of plywood as a background material for the direct fixing of ceramic wall and natural stone tiles.
Tiling Standards
Clause 6.1.2.7 Other sheets and boards (see also 6.2.3.3) now states:
“The use of sheets or boards that are subject to movement from changes in moisture content should be avoided. Plywood and other wood-based sheets or boards should not be used for direct tiling”.
A significant uplift in the use of tile backer boards and a wide variation in quality of plywood available on the market has provided a solid case for the removal of plywood from the standards.
David Wilson, UK Head of Technical Services a member of the TTA Technical Committee said: “Previously it was recognised in BS5385 Part 1: 2009 that tiling direct to plywood was possible, providing this was restricted to small areas and be “installed in such a way that they provide a [dimensional] stable and rigid background” the quality of plywood for tiling purposes has decreased significantly with cheaper imports flooding the market.
“While higher quality external grade plywood is still available – it is significantly more expensive.
“It is important to consider though that that wood is a hygroscopic material which means that its moisture content will change dependent upon any changes in the environmental conditions on site. Therefore, dimensional stability of wood-based boards cannot be assured there is always a risk to installing ceramic or natural stone tiles onto plywood or other wood-based sheets,
Another technical consideration for wall tiling is weight restrictions. Just as a side note at this point, if you don't have a clue what any of this is, then consider a tiling course, and research it well before paying any money. Plywood is deemed to have a maximum weight of tiling per m² of 30 kg compared to proprietary tile backing boards which generally are capable of supporting heavier weights per m² of tiling (As per table 3 of BS 5385-1: 2018).
British Wall and Floor Tiling Standards BS5385-1​
“A competitive tile backing board market means that prices are more attractive to tile fixers and contractors. This combined with the additional features and benefits of providing background for tiling which are dimensional stable and resistant to moisture and thermal movement. “
However, while plywood is not recommended as a background for direct wall tiling, it can still be used as a structural board when overlaid with a suitable tile backing board, particularly where installation of mechanical fixings is required e.g. for mesh backed natural stone where it is not possible to remove 75% or of the mesh backing.
Other changes to BS standards.
Previously in internal dry wall areas it was recommended that tile adhesive should cover a minimum of 50% coverage spread evenly over the back of the tile. However, driven by necessity, with the increase in the size and types of tiles i.e. larger formats and thin ceramic panels, now available of the market, BS 5385-1: 2018 advises: “Tiles with a surface area of less than 0.1 m², but which weigh more per square meter than 70% of the background’s capacity to carry the weight, should be solidly bedded e.g. the maximum weight of tile that can be supported by Gypsum plaster = 20 kg; whereas 9 mm thick porcelain tiles, which weigh approximately 18 kg/m², weigh more than 70% of 20 kg (14 kg) therefore, they should be solidly bedded regardless of their size”
British Tiling Standards included within the scope of BS 5385-1: 2018 are large format ceramic tiles, ceramic panels i.e. tiles with a surface area >1m² (any edge length >1200 mm) and thin tiles
i.e. ceramic tiles and panels with a panel thickness of ≤ 5.5 mm. To reflect this, additional changes have also been made in the minimum recommended grout joint width, dependent on the tile/panel size, e.g. the minimum grout widths vary by tile facial area – an example as follows:
  • For tiles with a facial area of less than 0.1m² with no side > 600mm long, a minimum joint width of 2mm is required.
  • Tiles with a facial area 0.1m² to 1m² with no side>1200mm long, a minimum joint width of 3 mm is required.
And
  • Joints between ceramic panels should be increased pro-rata to panel size (e.g. for a 3m long ceramic panels the minimum required joint width between these panels is 5mm.
Not included in the scope of BS 5385-1: 2018 are:
  • Natural Stone Slabs i.e. stone which is more than 12mm thick,
  • Agglomerate stone,
  • Metal, plastic resin, mirror or glass tiles of a similar construction
Note from Admin: We have collated most of the threads regarding tiling standards. Having one thread on the subject should help those out seeking advice regarding British Standards in Wall and Floor Tiling BS 5385
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
The BS5385 is the Tiling Standards , i have them and payed £120 for them, they are just full of technical info that either you wouldnt understand or you dont need, came in handy for me when i was doing my assessors and level three, but apart from that i wouldnt bother, you will get what you need from BAL product guide as it has the fixings to different surfaces in, thats all you need to know
brian c
i agree with Dave,but how many times do tilers refer to BS on a weekly basis etc...especially domestic but i presume that its different for commercial as site agents and architects etc are involved.Put it this way i have never had a customer quote to me any BS,unlike if i get a plumber for my gas boiler i will ask and request to see his corgi certificate.
GazTech
I would prefer if they were rules....but they are guidelines. I see some catastrophies in my occupation and hearts broken. The jobs that are done according to BS are at least safe, and are a good foundation for some kind of regulation. The rest is down to the integrity and skill of the person choosing work accepting them ,utilising and teaching by them, BS is all we have for now......Gaz
White Room
My girlfriend used to work for BS, She was working on the glass section and you would be amazed how many people would ring up checking the BS number on their double glazing to check that it was legal. Companys have to pay a yearly fee for the priviledge and the testing is stringent. The company she now works for is BS registered and they visit every year to check on health and safety. Just to finish of when visiting the tile show I was given a thing to hang round my neck with my badge on it, She made a comment that BS would,nt of allowed that because it would,nt break if it snagged or caught on something because it was around my neck.
pjtiler
you have your bal hat on there gaz
off the record
you know as well as me the BS is a load of *****
it changes day to day
you must have seen some of the crap tiles that carry the blessing of the BS label
travertine, B&Q for ex sample
MICK the Tiler
I won't be a formal voter as I'm not familar with the in's and outs of BS, but in saying that an informed tiler is a smart tiler and if your new to the game you should purchase and study the standards to become familar with there contents.
Yes they are a guide and yes they are rules, but the rules will come into play if a matter goes to court, so the court will look at a particular standard as a benchmark to which the work has been carried out.
Reply to Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
I keep this to hand now so I can show customers Tuesday, 24th July 2018 Important changes to...
Unused Account 1
U
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Tiling Standards
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
