Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com.
Rich
Min of 15mm BWP ply and then 6mm cement board, really not worth messing about with. Also might need to add some extra noggins before the ply goes down. Seal the underside and edges of the ply, leave a 2-3mm joint between the boards (that should be staggered) and screw down about every 200mm centers. The cement boards will need sticking down with either tile adhesive or glue, depending on the brand of boards, and then screwed down. Then you should be good to rock and roll :thumbsup:
Carpello
Just had a chat with a rep from a tile shop and he says.......'no need to glue/adhesive Hardi Backer down, but 200-300mm centres a must'
It seems within this industry, from top to bottom, everyone has good advice which often conflicts with others good, advice.
Im certainly not looking to cut corners in anyway but is with 200mm centre screws into the Backer board is there any need for glue/adhesive??
Rich
Yeah, you dont want any voids between the cement boards and the ply below, these can cause the tiles to crack and lift.
Most staff (not all) get plenty of training in how to sell products but very few of them have ever used them. This isnt an opinion thing, this is the manufacturers installation instructions. Iv seen a lot of trades and customers lay these boards and just screw them down because they havnt looked into how to lay them and it usually ends in tears.
Carpello
Brilliant advice, thank you. Just need to gather as much info as possible as this will add time to the job which will need to be explained correctly to the customer. I would rather take a bit longer knowing i am in line with manufacturers installation instructions etc.
So, just re capping (excuse my ignorance!) if i lift the existing tiles and board with it this will more than likely leave me with exposed joists?? I then put down a marine plywood 15mm min thickness (screwed into joists) then tile adhesive with 6mm Backer board on top..........???
Carpello
Nice one!! This may explain a few things......the house is 15yrs old, so fairly modern. The existing grout is starting to crack which is what set the alarm bells ringing when pricing up the job.
I have also heard of other people in the area with similar problems in upstairs bathrooms. Im now thinking when they built the house they prob just tiled directly onto plywood of some sort and now experiencing similar problems which your thread relates to.
That thread is spot on and will now give me confidence to explain to customers on why my quotes include extra time to prepare the floor and confidence when i walk away knowing i have done everything correctly.
Once again....that thread is quality.
Thanks for your time
Rich
I will put money on it being chipboard, see it all the time. Builders dont like to pay for ply and just get the tiler to tile straight onto chipboard because its cheap and then the floor fails :mad2:
Really glad that we have helped, thats what the site is for :thumbsup:
The Legend; Phil Hobson RIP
I agree with Rich on this spot on advice. I recently ripped up 3 bathroom floors in the same house. The builder had told the customer he had installed a special backer-board, imported from the US. When I lifted the first tile ( using a scraper, and very little force) low and behold, what do I find? chipboard,:mad2:
Reply to Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
I keep this to hand now so I can show customers Tuesday, 24th July 2018 Important changes to...
Unused Account 1
U
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Tiling Standards
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
