Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com.
Time's Ran Out
Difficult one this!
I've got photos of a job we did with handmade Fired Earth tiles last year and they were all shapes and sizes. Having used similar over the years I could see the effect they were going to have and the style that the customer was looking for.
However if a tile is not meant to be 'aesthetic' and you feel they lack the quality to complete an acceptable job than the onus is on you to make a decision prior to fixing the material - as that is when the manufacturer passes the responsibility to the fixer.
I'am sure that lippage (often highlighted by downlighters) has a standard of acceptance, but if the customer is bringing this to your attention then, unless there is a hidden agenda, you will need to rectify the problem tiles - at your own expense.
One Day
Answer from BS5385 Pt1 2009:
"7.1.9.2 Across joints
There should be no appreciable difference in level across joints
(commonly called “lipping”) and the maximum deviation between
tile surfaces either side of a joint, including movement joints, should
be as follows.
a) Joints less than 6 mm wide, 1 mm.
b) Joints 6 mm or more wide, 2 mm."
Remember though, BS is a guide, not a target.
No good getting nicked driving dangerously past a school at 8:55am and arguing the speed limit is 30mph!
One Day
This too:
"7.1.9.1 Finished tile surfaces
The surface should be true such that, when checked with a 2 m
straightedge with 3 mm thick feet at each end, the straightedge
should not be obstructed by the tiles and no gap should be greater
than 6 mm."
"There are permissible manufacturing tolerances for ceramic tiles
defined in BS EN 14411; certain types of tiles, e.g. extruded or large
format, might have permissible surface flatness irregularities that
cannot satisfactorily be accommodated within the surface flatness
tolerance permitted to the tile installer; this should be taken into
account when evaluating the achievable flatness of a wall floor tiling
installation."
One Day
I know where you're coming from kopthis, I've been there before. But I think you're wrong to say "does BS allow tollerances for lippage".
Ultimately, if you knew the tiles were so poor as to make a decent finish impossible, then you shouldn't really have agreed to brick bond.
Third bond perhaps.
As I say, I've been there and it's a tough call. Do you lose the job by sticking to your standards, knowing that someone else will do it and be paid?
If I were you, show the customer the first part of the BS extract and ask them to put themselves in your shoes.
You explained the problems with the tiles so they MUST bear some of the blame for the result.
You can only polish a turd so much before it all breaks up in your hands!
One Day
Ever noticed how porcelanosa insist from a design point of view that their wall tiles are fixed straight?
And by and large they are pretty damn perfect.
I've seen a touch of bowing on the long floor planks and then they ask that they are only ever 1/4 or 1/3 bond.
I always try and convince my customers that brick bond is "so last year darling!"
Stef
think someone from that big DIY place should start looking at some of the tiles they are selling, i have been shocked at some of the tiles we have been asked to fix. we tell people if you get tiles from there then our price will be more expensive. Its a tough call this 1, states on the boxes that its the fixers responsibility to check tiles before fixing, good luck hope it works out in your favour.
Stef
yeah i will agree with you on that one. Porcelanosa for me. i went right off brick bond start of this year as thats all we seemed to do for about 3 or 4 years. we have used a tile from china, cant remember the name, came from (guangdong province) & they were perfect. 600x300's think they were from tile giant, when i saw them i thought they were going to be crap.
Spud
when using bowed tiles the convention is to measure the bow in the tile and add this to your standard joint width so if the bow is 1,5mm then you add this to the spacing size, but I couldnt imagine fitting wall tiles with such large joints, lets face it some tiles are not fit for purpose and years ago they would be classed as "seconds"
Mike
Yup, I've worked with some large format rectified chinese ceramics, white bodies. I think they were made by Winter-something-or-other.
In any case, they were bang on. Managed to wet cut a millimeter sliver all the way down the length!
i used the same ones i think, winto they were called, around 600 by 400. nice tiles to cut and fit.
Reply to Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
I keep this to hand now so I can show customers Tuesday, 24th July 2018 Important changes to...
Unused Account 1
U
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Tiling Standards
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
