Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com.
U
Unregistered
Could anyone tell me if there is such a thing as a British Standard for grout width? I have a big problem with 600 x 600 rectified tiles that have been put down. The grout line is about 7mm, up to 10mm in places, and it is also extremely low so that when you wash the floor the water sits in the grout lines. The tiler is saying that they have been fitted within British Standard. They look dreadful, especially when compared to the same sort of tile we have elsewhere where the grout line is more like 3mm and the grout is level with the surface. I appreciate your help.
The D
I had the same thing on a job I did last year I fitted a 5mm joint as the type of tile I was using I had always used that size joint. The floor took me two days to do a day and a half tiling and half a day grouting in all that time they had seen what I was doing and said nothing but as soon as the job was finished they Said they did not like the size grout joint I had used and could I change it. To be honest I was absolutely fuming but as I had not discussed the joint size with them befor I started tiling I had no option but to lift the floor and retile it using a 3 mm joint. I always ask what size joint people want now.
Jackie0802
Jackie0802
Sir Ramic that is just one randomly selected of lots of pictures, others are much worse. Afew weeks ago I posted on here about the sunken grout lines in this kitchen and some of you made some good suggestions. I only told you half the story, but basically we have almost 70m2 like this, and some of the tiles are so uneven that you have to lift the chair over them rather than pulling out from the table. When the floor is washed water sits in the grout line because the grout is so low. The tiler said the problem could be rectified by replacing some tiles and re-doing the grout. We bought an Exact tool following advise from some of you guys and 30 new tiles (all at our expense). The result of the 'remedial' is truely horrific, basically the replaced tiles are even higher than the originals, the grout line was far to wide for the tool to have any effect and 18 good tiles have been horribly chipped by the 'remedial' process. We are now being quoted this BS standard of a grout line of 6mm - 10mm whereas everyone else seems to say that a 3mm line is more in keeping with this type of tile. I should add that this tiler has done several jobs for us before without a problem, so we just didn't see this coming. So far the cost of the 'remedial' has cost us about £500 and we are worse off. The tiles now have to come up and it is going to cost about £5000 to put it all right and all the tiler wants to do is quote British Standard!
Reply to Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
I keep this to hand now so I can show customers Tuesday, 24th July 2018 Important changes to...
Unused Account 1
U
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Tiling Standards
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
