Important Changes to Tiling Standards
Hi,
Just a quick question, doing a bathroom at the minute in a factory, put a 2.4m straight edge on the walls and they are not flat invert inwards. Does any one no the tolerance of the plasterboard and tiles? they are 600x300 porcelain square edged.
Put a 2m long straight edge anywhere on the plasterboard and if there is any gap greater than 3mm between the straight edge and the board then it is not flat enough to tile.
On the tiled wall do the same test using a 2m straight edge with 3mm feet each end. If the gap between this and the tiles exceeds 6mm or the straight edge touches the tiling then the tiling does not meet BS.
This is based on my memory of reading BS5385 a while ago (I no longer have an up to date copy).
The same tests apply for the flatness of a floor substrate and floor tiling.
On a large floor the surface should also be flat within +/-15mm of the datum or as per the architects specified tolerance. I don't know the equivalent wall building tolerance.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
