Discuss Tiling top of window with air vent in the UK Tiling Forum area at TilersForums.com.
Batt284
Hi All,
I am planning how to tile around my window, but the vent at the top is causing me a bit of a headache. It is too smaller gap to be able to slide a tile in behind. Tiling right up to the vent would prevent it opening (it slides accoss and out). Have any of you tiled around one of these before? There is a Roman style blind going up (you can see the 2 fixings) so I guess it could hide the edge of the tiles. Just want to get it right!
Deleted member 9966
hi Batt284
my windows in my house have the same kind of vent systems in the frames. you should find that these things simply screw into the plastic window frame. there must be a way of knocking the end caps off that are hiding the screws. as soon as you have uncovered the screws, you should just be able to unscrew it and take it off. we did this in my bathroom last year as we tiled all the way round inside the window reveal. unfortunately, the thickness of the tile was slightly too much to allow the vent back on in it's original place, so we simply screwed it back on but lower down the frame by 1-2mm.
so in short, you should be able to find screw caps which cover the screws that fix it to the frame.
hope this helps
GRR
Reply to Tiling top of window with air vent in the UK Tiling Forum area at TilersForums.com
WHOLE BATHROOM REFIT - ALL WALL FULL HEIGHT TILING AND TILED WINDOW LEDGES. ONE SMALL WINDOW &...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi, Planning on tiling with a "border tile" along the top. It's an inset area with a sink, 2...
