Discuss Tiling uneven wooden floors in the UK Tiling Forum area at TilersForums.com.
choco
Hi all, a plumber here. My wall tiling isn't bad as I take a lot of care over it, but I haven't done that much floor tiling.
I've got a bathroom (1.7m x 1.9m) and a small cloakroom to do. It's an old house and the existing floor boards are all over the shop. Very uneven with gaps and corners missing, etc.
I am thinking of screwing down the boards as tight as possible, then putting down a sheet of ply (not sure what thickness, though?) and then using one of those floor leveling cement jobby things on top of that.
Am I going far wrong with that? Some recommendations on which adhesive and grout would be appreciated. Cheers.
Perry
Yes you could try screwing down all the exsisting floor boards then over laying them with 6mm ply screwed at 300 centres
Then use 6mm hardi board put that down with flexi adhesive then screw and tape all the joints leave a gap of about 3 mm
hope this was helpful
He he is it because he is a plumber
choco
As an update, I've cleaned all the rubbish out of the bathroom this morning and the floor is in a lot better nick than I'd remembered it. The loose and uneven stuff is on the side which will be under the bath. The standing/walking areas are actually very well fastened with tongued and grooved boards.
Taking into account the info offered so far, I'm considering glueing the hardie board stright onto the boards.
macten
1,158
Nottingham
Am going to be testing a new product soon that will help make floors with dodgy floorboards alot easier to sort whilst keeping height rise to a minimum. Not allowed to mention the product yet but will put up a review once I get the okay.
peteablard
1,058
Cheshire
I know, it's 6mm ply :lol:
True Tiling
Take up any old floor boards you have cut to bits when you were plumbing and replace with noggins. Secure with decent length screws all along joists. Place a cup of water in one corner. Jump up and down heavily. If minimum deflection, then brace the whole floor with 9-12mm marine plywood (sealed on back and edges). Then cross your fingers and tile it my plumber friend.
Reply to Tiling uneven wooden floors in the UK Tiling Forum area at TilersForums.com
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
