Discuss Tiling wall, cable protruding from wall in the Canada Tile Advice area at TilersForums.com.
Graham
London
Hello folks, I just finished installing my base and wall units and now need to tile the kitchen. I'm using 10cm x 20cm metro tiles, and will tile up to the bottom of the wall units (so about 60cm up from the worktop, which I am fitting first).
I thought about this and realised that a lighting cable, which I need for later, is sticking out the wall. Do I drill a 20mm hole in the ceramic metro tile and just pop the cable through it? Or maybe I should insert a rubber grommet in the hole and then push the cable through that?
Any advice appreciated.
Reply to Tiling wall, cable protruding from wall in the Canada Tile Advice area at TilersForums.com
London
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
