Discuss Tling over old tile adhesive in the Canada Tile Advice area at TilersForums.com.
How much prep does this surface need before re tiling? Will the new tiles adhere properly if old adhesive is left behind?
I think the actual question is, do I have to scrape up all the old adhesive, or can I just go over it??
Dunno, we can't see how good or bad it is. Maybe a picture might help?
A scraper with a blade on it should be able to tackle it..
What does the Tiler say about it?? Is he happy with the prep??
rich hand
If the Fastflex cracks I have already advised the owners that the joists should have been strengthened and that 15mm ply (not 6mm) should have been put down. They want to trial this situation rather than remove the bathroom suite, especially since it is hardly costing them anything.
Maybe the old adhesive was flexible standard or simply standard non flexible we do not know. However, it has stuck to the ply well just not the ceramic tiles. Since it has stuck to the ply well I was wondering if it really needed to be removed. It does scrape off if necessary though. There is only a couple of mm depth of adhesive.
The ply is on floor boards beanz.
On this job, I am acting as the tiler, I have done much work with stone floor maintenance including tiling, just not tiling on board.
So its 6mm ply??
How well is it stuck down? Nails in every corner and 1 or 2 scattered around, as per Joiners usual prep standard?
Least you can book them in next year for it doing again. Cool.
The D
If it was not modified it would probably not have stuck to the porcelain tile at all. Personally I would not be happy tiling on to 6mm ply and would be advising taking the ply out of the equation.
Can’t understand why the ply can’t be removed it would not take much effort to lift 6mm ply and replace with backer board
beanz
Berkshire
To be fair, that's been explained. Customer wants to try and fix tiles without ripping up the floor 1st. Upto them if they want to throw good money after bad..
Rich, have you tried getting the adhesive off the tiles yet?
The D
the customer need to be told that 6mm ply is not going to work.
beanz
Berkshire
Who says he's advised 6mm Ply!?! The impression I get, is that he's advised 15mm Ply, but they want to try this first. If he's going to get paid to do it twice, because they refuse to listen, good luck to him.
as for having a problem Deano, I'm no sad *** Internet warrior, you fill your boots mate. ;)
Reply to Tling over old tile adhesive in the Canada Tile Advice area at TilersForums.com
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Hi all, I removed some old tiles from the shower and wanted to know if it's possible to tile...
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
