Hi All
I placed a 'tiler wanted' ad recently and have had 4 people out to look at the job, so thanks for the great response everyone!
All 4 guys seem to know what they're talking about. The issue I have that 2 suggest that Ditra matting should be laid underneath my tiles, 2 say that in my case it's not necessary.
I am less concerned about the extra cost than I am about the extra depth it will add to the finished floor. I won't go into details as to why this will be an issue but trust me, that extra 3 or 4 mm will make all the difference, and I'm really (really really:smilewinkgrin keen to avoid it.
My subfloor is an old building (so all well settled). timber joists (that I have doubled up joists in couple of areas where approx 1.8m between brick supporting piers) over which I've screwed down 8x2 ft 22mm T&G green floor chipboard (old floorboards removed first). After decs are all complete I'll be laying 8x4 ft sheets of 12mm WBP ply at right angles to floorboarding screwed down at 100-150mm centres and well unibonding over to seal. The floor already has absolutely minimal 'bounce' and that will only be improved with the ply.
The room is a kitchen approx 7.5m x 5.5m. The tiles are 600 x 400 x 15mm Moleanos Limestone that will be laid brickbond down the length of the room. Plan to allow to lay then 1 coat sealer, then grout (say 4mm) then 3 or 4 further coats of LTP Mattstone sealer. Adhesive I've purchased is Larsen Flexible standard set white. Grout Larsen Flexible narrow joint limestone colour.
I have had stone floor laid over various timber subfloors before and never had any issues with cracking. Generally they have been Travertine though and not limestone.
So, question is, to Ditra or not to Ditra?
And yes, I appreciate the 'better safe than sorry' argument but as I say, that extra depth gives me real headaches.
Thoughts/recommendations/warnings/assurances appreciated...
Cheers
Paul
Cheers
Paul
