biffta
dont use marine ply , use " no more ply" good price easy to cut, easy to transport, always lift toilet. you know it makes sense. good luck
Thanks, this seems pretty good stuff.
You have got about 3/4" on your pan connector. You could try gaining another half by working the pan connector up. Be gentle though and not too much
Could you explain a little more about working it up? Do you basically just mean rocking it back and forth?
IF - the wc pan doesn't go back on after tiling purchase an offset pan connector an a length of 2"x1". Install the offset pan connector straight into the current 90 degree and install the wc. The timber is to baton the cistern. The offset will pull it forward from the wall so screw the baton where your current cistern fixings are then screw the cistern to the baton.
Ok this seems to make sense. I'm guessing I'll need to get some sort of special sealant to fix it altogether with?
My main worry with this is that the water pipe comes up vertically from the floor and will need to be bent a little to reflect the new position of the cistern. I'm guessing this might be an issue as I've no experience (or tools) with copper pipes.
