Discuss Tool Storage solutions in the Canada Tile Advice area at TilersForums.com.
Dumbo
Power tools were (and are being replenished) into makstack cases.
Ply lined and shelved for my main Sigma cutters.
Box shelving for spacers, clips, tubes etc.
Wet saw, tool bags and boxes have their spaces.
Mixer has a space stood up and secured.
Trowels are quick-release secured on my doors using strips of tile trim.
I hate anything rattling around!
I have makstack for electrical tools griders, drills etc . I am finding the catches a pain , also I broke one the other day , i think the plastic is to brittle so they will be getting swapped out for another system
If your lucky enough to have a garage, I'm sure it's much easier to keep organised and carry only what you need to. My new years resolution it to stop carrying 8 part bags of grout! I've had the same ones since 2014 and there not getting used :p
Storing sigmas is an issue also.
Why don’t you put a false floor in so that you can slide your sigmas under it?
I’ve seen a few do it.
Nic_P74
513
Oxfordshire
Still need to rack out the van. Too busy working to do it. Will no doubt get it done in the New year. Bound to be some slack time.
Started transferring all my tools into these.
Nic_P74
513
Oxfordshire
Yeah I've seen a few do that and it probably is the best option, wouldn't need to be full length either. Think I'll get some timber together and have a day on it see what I can knock up.
I’m going to try to make it so I can have the main floor of the van pretty much free so can load full 8x4 sheets and other materials or load up wet cutter or big mitre saw and stand.
I’ll be presumptuous and take it you’re replying to me Andy :D if you design it right you can fit backer boards in there too.
Not too many of course, just 2 or 3 to get you out of trouble now and again.
I’m sure there’d be room for boards one side and Sigma the other.
I think they need to be a snug fit to avoid sliding about, and a nice thick board to avoid sagging, central spine. I'll get on with it in Jan!
Split your floor in half and get some thick foam to wedge in against your cutter. It doesn’t matter then what type of cutter you have, or indeed what you slide under the floor.
Of course an ungrateful clients body won’t make a noise if it moves about anyway.
One Day
They aren't the best for sure and I agree the catches are stiff and difficult.
I found a squirt of Silicon spray really helps though.
Reply to Tool Storage solutions in the Canada Tile Advice area at TilersForums.com
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
