Discuss Travatine in the British & UK Tiling Forum area at TilersForums.com.
Teesider Tom
Just landed a job to lay Travatine, never tackled this before, just wondering what essentials I need to know.
Going to seal them before grouting, but how long do I have to leave them after grouting before sealing them again?
I assume they all have to be wet cut, will a small Briccolina do? Will I need a new blade before and after?
Normal sp flex adhesive for the floor? Any special grout or normal flex grout?
A few questions I know my first time with stone.
Thanks:stupid:
GazTech
Thanks for the reply Gaz.
Yes, the tiles are going onto a floor, a concrete one.
My cutter has a 17mm blade, not too sure how thick the Travetine is. If the travetine is thinner my cutter will be ok? What about the blade, had it for about 7 months and only cut ceramic and porcelain.
Give the cutter a go, most travertine is quite soft anyway I would get a new blae to have ready for when you start as back up. Concrete is perfect surface, prime the surface frst and then use a white single part adhesive or rapid set, they don't need to be flexible. Same with the grout, be sure to clean after tiling and seal the trav before grouting, a second sealer can be applied at a later stage when grout has set properly......Gaz
BAL Bond SBR
A waterbased polymer with a wide variety of uses in the construction industry, particularly as an admixture and bonding agent for cement and concrete applications. Once cured, the polymer is water and frost resistant. BAL BOND SBR can be used as a slurry coat when mixed with hydraulic cement or gypsum plaster, as a multi-purpose admixture for cement:sand mortars, concrete and gypsum plaster; as a brush applied primer, sealer or dustproofer.
Suitable for use on cement:sand screeds, toppings or renderings, plastering, waterproofing, bonding, concrete repair, priming and sealing.
BAL CTF 3
White, cement-based, polymer modified, non-slip, water-resistant and frost-resistant adhesive suitable for fixing ceramic wall and floor tiles, ceramic mosaics, quarry tiles, natural stone, terrazzo and brick slips. Suitable for a variety of backgrounds/bases including concrete/brick/block walling, cement:sand rendering, gypsum plaster, plasterboard, fibre cement sheets, cement:sand screeds, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet, mastic asphalt.
BAL Wide Joint Grout
A water-resistant, frost-resistant cement-based powder grout designed for grouting ceramic floor tiles, mosaics, quarries etc. Also suitable for use on walls. Not recommended for soft glazed wall tiles, or tiles with metal decor or lustre. Suitable for use in interior and exterior locations in both wet and dry conditions. Suitable for swimming pools. Conforms to BS EN 13888, Type C, Class G1.
This is available in Limestone, good for travertine
Reply to Travatine in the British & UK Tiling Forum area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
We have just laid an outdoor patio and path using black limestone (now wishing I’d perhaps...
Travatine
Tags
usa
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
