Discuss Travertine advice!! in the Canada Tile Advice area at TilersForums.com.
Dumbo
The problem there normally stems from the MC washing the floor/walls down the day before you come in to complete because they have sneaked in other contractors while we are away from site. Its like the wild west out there.
So how does your low water content adhesive help with that .
M83T
183
Devon
So just to clarify because after having read all the stuff about water staining and such I'm now not sure. I plan to use BAL white or green star ready mixed addy (I'm still learning and therefore quite slow and I find ready mixed easier). I will then seal with (what's the best sealer to use please?) Grout then seal again.
H
hmtiling
Any slow set white c2 powder will be fine. You don't need low water content adhesive. Rapid universeal all in one would be my choice as reduces drying times.
Dumbo
Green star is rubbish for anything . White star is good but I wouldn't use it for that. I would use a good slow set powdered adhesive . Probably something like kerracoll biogel or isomat ak20 very user friendly if you follow the mixing instructions . As for sealer lithofin mn stainstop if you have time or universeal rapid if you haven't.
M83T
183
Devon
Ok I've used the green star before and I got on ok with it but guess it wouldn't hurt to move on to powder addy. I know the chap I'm doing it for has bought some cheap white powder adhesive from the builders merchant so I'll try and get persuade them to use something else. The kerracoll would be fairly slow setting as I'm not the fastest (yet)?
Hi everyone, my friend has asked me to tile their kitchen walls and having recently done my own kitchen splashback I accepted the offer to gain some more experience.
I've just seen that the tiles they have selected are 200mm X 100mm travertine tiles. I'm now slightly apprehensive about doing this as I have no experience of using travertine, I'm happy with setting out and stuff, but the adhesive, grout and sealing side of things is what's concerning me is it a completely different approach compared to normal ceramic? Any advice on working with travertine would be greatly appreciated. Thanks.
We always recommend pre sealing stoneprior to installation. Any Silicon or paraffin based system will protect and beautify your stone work. Allows for easier cleaning too. You could use AquaTight Hydraguard which protects, seals, protects natural stone image.
Reply to Travertine advice!! in the Canada Tile Advice area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Devon
Travertine advice!!
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
