I
IHB
how much do the tiles weigh per m2...don't forget you have to allow approx. 2kg per m2 for the adhesive and grout..
Is that 2kg per m2 per 1mm of adhesive depth?
The boards must be rigid and I note that you are tanking the walls which is a must. The weight of Travertine tile and adhesive would be in the region of 32kgs/m2. However, be careful the market is flooded with cheap Travertine mainly cross cut which is full of voids and fillers. Travertine being a soft stone is likely to attract soap residue and dirt it is not the best finish for areas constantly in contact with water. Bob Howard MBE
but if it was to fail and weighed more than the recommended limit surely it would be none other than.... the tillers fault lolAll travertine is different. I did a bathroom with 16mm tiles honed and filled. Actually weighed a sq mtr on the bathroom scales and they came in at 29kg so with addy and grout were just on the limit. I checked with BAL anyway and they said the 32kg was a "safe" number and not to worry. You'll be ok.
