Printisdead
I've recently purchased honed and filled travertine 400mm x 300mm x 10mm tiles. The main isssue is the walls around my window are not plumb and the window recess is not a true 90 degrees to main wall.
I'm not a tiler but a bench joiner with an eye for detail. Its very important, especially in natural stone. (I'm taking the time to polish seen edges not using trim, looks awful!!!). So as you can imagine I want 90 degree corners around the window, no tiles kicking in or out.
The main problem is that in certain areas I will have to bring the tile off the wall (to a max of about 12mm). I thought about screw and plugging plywood shimes/packers on to the existing plastered wall, apply adhesive on top and then setting the tile directly to this. This would allow me to adjust the shimes and tiles accordingly.
Would this work as a good soultion? Any tips or advice would be very much appriciated
