Discuss Travertine mosaic problems. in the British & UK Tiling Forum area at TilersForums.com.
ohhnoo
I'm having problems putting up travertine mosaics the sheets measure 305mmx 305mm each idividual tile is 48mmx48mm and 10mm thick. I'm using a 4mm square notch trowel and normal set time adhesive, should the trowel notch be smaller. The weight of the mosaics is making them move and all the grout lines close up especially the horizontal. If I use spacers it makes it difficult to get the mosaics flat and level, I tried mixing adhesive a bit stiffer to help as the mosaics are thinner so the adhesive bed needs to be 2mm thicker but still no good. Suggestions please or is spacers the only way.
doug boardley
if it's not in a tanked area, I usually hang them like curtains and tap panel pins at the underside of the top course per sheet. This stops them slipping and gives me enough room to tamp them in with my grouting float. I normally use rapid set too (mixed in smaller quantites). With that depth of mosaics I'd probably "up" my trowel to a 6mm notch too:thumbsup:
ohhnoo
I take it your matching up to larger tiles
you will need to dub your mossaic bed out 2mm and let that dry and trowel the correct depth with your mossaic trowel
too much addy will cause you grief when fixing and wont grab the mossaics into place
Thanks Mike:thumbsup:Yes I'm matching upto 12mm thick tiles, the face of these is about 16/17mm from the wall surface once stuck on . So you're saying a 2mm bed (will that be enough) allowed to dry then will the 4mm trowel be ok or should I use 6mm.
ohhnoo
Thanks Doug. Good idea that but it is a tanked area, so I will use the method suggested by Mike. So I should be using a 6mm trowel and would be better off with quick set.
kilty55
1,113
edinburgh
gat a baton or tile,measure the distance between main tiles and mark on the baton or tile.
say you have 4mm to pack out with adhesive to acheive your perfect depth using your mosaic trowel then cut out the required depth of the tile or baton you have marked on either side of it and run this along your mosaic line after filling with white cement based addy this will give you the exact bed you need,hope this makes sense
also use a float to dab and pad the mosaics onto the bed this will help them stay flush allover instead of using your hands which wont give you a flat finish
doug boardley
theres an easier way to lay mosaics perfect everytime if I told you I have to kill you very simple a clue you make a tool from scrap tile a" rule?" If I could draw it youd know Ill put up a pic later with the solution youll never do it diffirent throw the notch trowel out the window.
Intrigued:punk:!
ohhnoo
:thumbsup:Please post the picture.
ohhnoo
Is this what you mean cause thats what I've made out of perspex, not tried it yet. I've made it so its 13mm from the surface of the travertine
Reply to Travertine mosaic problems. in the British & UK Tiling Forum area at TilersForums.com
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
I've got some large tiles from Porcelanosa to fit in a quadrant shower enclosure. The tiles are...
Looking for some adhesive advice... DIY bathroom job, 600 x 600 porcelain tiles 26kg per sq...
Dumbo
Hi guys, Last time I posted here I was having a first attempt at tiling the walls in a shower...
Waluigi
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
