Discuss Travertine outside? in the UK Tiling Forum area at TilersForums.com.
I thought it would be to soft, he wants a look of stone like travertine, any ideas on something good to use? Maybe you guys have done one before you might have pictures of.
I was just going to look for a stone effect porcelain.?
I'll get a picture of the step tomorrow and post it on here and see what you guys might do with it. Cheers.
Topshop
One thing that seriously effects travertine or any other natural stone outside is what it is set on. Most installers put it onto a cement base and do not put a moisture barrier between the ground and the cement so moisture migrates into the stone from below the concrete.
The right way to do it is put down a barrier(heavy plastic sheet), pour cement, install tile, seal the heck out of it with a UV stable sealer.
A denser (no voids) travertine would be best to avoid water settling into pockets, freezing, and breaking apart the stone. Most travertine is not filled with UV stable products and it may be difficult to find a stone that is free of voids.
Tony73
1,233
acton w3, london
correct :), you could use travertine effect porcelain or portland, or york stone
PHG Dave
A good quality travertine is fine for outside.
When i first looked at travertine for outside i was sceptical that it would withstand water freezing in the holes so i tried an experiment of my own. I took a number of pieces of travertine in both 30mm thick pavers and 12mm tiles, soaked them in water and then put them in a freezer. I even topped up the holes with water and then left them for a couple of days to freeze nicely before taking them out to thaw out.
I carried out this freeze/thaw cycle several times and still no damage to the Trav.
The pieces, including the 12mm versions have been sat outside in my garden for the last 4+ years and are still as solid as ever!
Ajax123
1,213
Lincolnshire
Then I withdraw my comment. Sounds pretty conclusive to me. To be considered suitable for outside it has to go through a certain number of freeze thaw cycles. It used to be fifty for concrete. not sure if that changed with the latest standards.
Reply to Travertine outside? in the UK Tiling Forum area at TilersForums.com
6K
First of all, I'm sure this question has been asked a thousand times so apologies in advance! A...
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
Hi all, I'm new to the forum but have read many posts over the past year as I have created and...
6K
Preston
Travertine outside?
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
