Guest viewing is limited
Discuss travertine shape cutting.. in the UK Tiling Forum area at TilersForums.com.
cja
Another day another question.. sorry!
Travertine, 12.5mm 610x406 on walls
Brick bonded pattern, need to go 'around' an alcove - it works out that visually it would look better to make the cut in a single tile, but i'm not sure if it's practical?
I've illustrated in a diagram, apologies for the pink - the picture on the left is how i think it would normally be done - 2 tiles, 2 cuts in each, polish the edges. However, on the right is how it would look better - 1 tile, 3 cuts - but i'm not sure what tool would be up to the job of making the horizontal cut? Any ideas?
Thanks!
astute1
Agree with Dave, I sometimes run my turbo blade along a straight edge. I have a number or 3mm thick L Angle aluminium ones, different lengths. Gives you a nice straight cut, especially if youve had a few beers the night before and your hand is a little unsteady. Generally just use it for a first shallow marking cut then remove and your blade has a nice straight trench to run along in.:oops:
Reply to travertine shape cutting.. in the UK Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
