grumpygrouter
Cement board is only just really starting to be used more over here. Most of our construction is plaster or plasterboard (gypsum) based. This doesn't have the same strength as cement board so we need to be a little more careful.I don't fully understand some of the terms & proceedures you guys use over there.
I have laid up to 600 x600 travertine on walls here without an issue. As long as the walls are built properly they should take any weight you can throw at them. Our walls are built with either aluminium or pine studs and cement sheeting, usually. With the occasional brick & or rendered walls, in domestic situations.
I would like to point out that the building of the walls over here are the builder/chippys responsiblity. Reading some of these threads it seems some of you guys build your own?
