Discuss Tremco CS175 epoxy primer in the Canada Tile Advice area at TilersForums.com.
Gazzer
This primer has been supplied by the screed company for an Anhydrite screed.
Looking at the instructions on the tubs it makes no mention of Tiling. It does say
"All aspects of the installation must be
in accordance with the requirements
of BS8204, BS8203 (Installation of
Resilient floorcoverings) or BS5325
(Installation of Textile floorcoverings)
and supplementary specifications."
It also states
"LIMITATIONS
Not for use as a primer for Tremco
smoothing compounds. Where a
primer for these is required, please
consult Tremco illbruck’s Technical
department."
Anyone ever used it, I wasnt going to prime as I will be using N&C Gypfix but it has been supplied. ??
Ajax123
1,213
Lincolnshire
It also states
"LIMITATIONS
department."
If you are using gypfix ths NOT the best primer. I have seen it used hundreds of times with cement adhesives with a good deal of success. However gypfix release heavily of the screeds ability to pull the moisture out of the adhesive once the gypsum reaction has completed and any epoxy will significantly reduce the screeds ability to do this. If you must use the epoxy use a flexible cement based adhesive. If you use gypfix a single coat of acrylic would be better. Ven better f the screed surface is sound no primer at all.
The screeder probably suplles this for all his screeds regardless as mst people will still b using cemen adhesives nd smoothing compounds and he would not generally know what coverings are going down....
Reply to Tremco CS175 epoxy primer in the Canada Tile Advice area at TilersForums.com
Anhydrite screed on kitchen floor with UFH. There were some hairline cracks which were bonded...
12K
11K
Rizzle from the Portizzle
Be the Best with BAL! The importance of correct training should never be underestimated. As the...
8K
Hiya fellas. I've been on a large anhydrite floor and thought i'd do a little test whilst i was...
19K
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
