Tricky Situation
  • Thread starter Thread starter rockyroo
  • Start date Start date
  • Tags Tags
    usa
rockyroo
I have just had the job from hell, I tiled a kitchen with more nooks and crannies than I care to mention, the woman wanted chrome trim around the whole lot and I told her that the walls would need to be as smooth as possible as there had been tiles on there before.
When I got there the tiles had been removed and the walls were not in great shape, looking back I should not have started the job but as I was there I thought that once I got going it would be ok!! (wrong). The chrome trim would not meet in certain places due to the wall being uneven and left some sharp edges, I thought that I would be able to soften these with the grout, all the way along I explained this to her and she seemed fine. I went there this morning only to find out that the husband had been home the night before and was not happy! We had a bit of a verbal and I ended up saying that I would not grout it as they were not happy with the workmanship and (when backed into a corner) said that I would reimburse them for the tiles(yes I know).
So angry with the whole situation, just annoyed with myself in the first place for even starting the job.
Has anyone else come across a similar problem and how have you dealt with it?
Cheers
I guess when you say the trim wouldn't line up from wall to wall, then the tiles obviously didn't meet up either from one wall to the next ?
Funny how the husband turned up after you had done the job. where was he when you said to his wife, the walls need smoothing off ? I would have followed up with the sentence, " you don't need a tiler to take tiles off and smooth the wall's" a tiler puts tiles on.
A lesson to us all I suppose. If your not happy with the substrate, refuse to tile it until it's sorted. even if you end up doing it yourself, charge them for it. make the husband dip further into his pocket, make him wish he'd should have done that bit himself.:wink_smile:
No the tiles met up, it wasn't the height that was an issue, it was the the right angles of the chrome not meeting due to the walls being uneven
If you used a sliding bevel to get the correct angle on the corners that were to be trimmed you would of got the mitres spot on.....just a small tip....
next time make sure the walls are ok before commencing tiling........dave..🙂
Bit tough on you there mate,plastic trims can bend a bit ....steel trims not as forgiving.
Nothing quite like being told what you already know, thanks dh !!
wasn't being funny but at the end of the day once you took the job on.. The problem walls then became your's......customers tend to think tilers can get over anything dont they..lol lol..........dave....🙂
I had problem last week like that,they wanted Chrome trim everywhere,was going really well until they said they wanted the tiles and trim all the way down by the sides of the new door that had been installed and I said fine without looking properly at the door.They'd had a new doorway opening done and when I came round to tiling round the corner bits the walls were SEVERLY out.I showed them the problem which they accepted ad said just do your best.I spent hours doing something that should take no more than 30 mins,had to drill the trim to the wall and fix with screws to bend it a touch,customers were were well pleased with it but to be honest I wasn't,won't attempt that again.
Whats a sliding bevel dave?
I know I can ....at a price,the longer you stick at this job the easier your judgement will be...........so stiff upper lip mate and chalk it down etc :wink_smile:
Tricky Situation
Tags Tags
usa
rockyroo,
Holohana,
rockyroo,
Holohana,
