Tiling Tool Suppliers
Discuss Trim Cutter search in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
mankey
I have both in my toolbox. The snips are fine for somethings, and not for others. I use both tools as much as each other, and find I can get an excellent finish from both.
In that case, might try both. Today I bought a plastic mitre block from Screwfix but none of my hacksaws nor the ones I could find today were tall enough to clear the block. Ideally I could order a mini block online, but I preferably need it now.
Ended up 'trimming' the top 5cm of the plastic block so the blade would reach all the way down. I could have used another saw but it's going to work best with a junior hacksaw blade that has a finer cut.
The mitre looks a right sight now, but it was only a cheap piece of plastic anyway.
tile55
I use the plastic cutter most of the time and finish it off with a sharp stanley blade, sometimes use a round end file to finish it off.
I use a hacksaw aswell, but not the box. I've had the blue mini mitre box for about 10 years, but it is in the back of my cupboard and does'nt get any use at all.
All in all I'm quite happy using the cutter, it gives a good cut, very quickly, then the knife finishes it off.
Try both methods, which ever suits, use that method.:santa_cheesy:
L
LM Ceramics
Sorry no idea, why not get a hacksaw and mitrebox instead, much better finish, i find the trim cutters crush the trim.
if used properly and you have some decent trim cutters then you can mitre just as good as an hacksaw quick and easy to use!
id stay away from the plasplugs one though i think topps or tile clearing house have decent trim cutters in
mankey
That's also good to know. Just goes to show I need to try the snippers to decide whether they can work for me. As I said earlier I now have not a blue but black butchered box, but you can still cut straight lines through it.
Cheers
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
The trim cutters are fine , but i find a hacksaw and a mitre box a lot easier....and om metal trims i use a file as well to dress the cut edge smooth..
You could also use a file on plastic trim to tidy mitres up etc...
Those plasplug ones do very flimsy though....if you deffo want a pair of cutters then buy these ones>>>>>> TradeTiler.Ltd Plastic Trims and related tools
you will se a good quality mitrbox and hacksaw there as well....
I agree with dave there, the plasplugs you can cut through! lol
mankey
Topps had never heard of them when I called in this morning. Will order from somewhere online and use the hacksaw in the meantime.
Yes, will stay away from Plasplugs
Reply to Trim Cutter search in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Can you tell me what the best mitre cutter out there for cutting chrome tile trims. Is there a...
my trusty old wickes wet tile cutter never got returned last time i lent it out. but only cost...
5K
Hello all, I'm tiling my bathroom and using 360 x 240mm white tiles on the main walls, and 100 x...
Hello so need some help please, any ideas where i can purchase a 9mm external brushed crhome...
5K
Dumbo
Hi all. Finally started cuts on floor tiles today and few questions re cutter & tiles: Usina new...
9K
Jock McG
Popular Tile Cutter Threads
Trim Cutter search
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
