Discuss Tumbled travertine edges , best way ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Gez2312
Was thinking of getting a half bullnose for the polisher, tiles are 10mm , would a 10mm or 5mm half bullnose be better ? If I got a 10mm I would just clamp tile to a piece of ply so the bearing on the cutter had something to run against ? Just thinking this may keep them more uniform than freehand with a pad
gamma38
1,058
Bedford
Yes i have the makita variable speed. Great piece of kit. Makes short work of trav. I use the glue backing pads and have 4 set up with different grades. 125 to start then 200 then 400 then 800. To polish I prefer switching to the diamond pads above 800 as i get a better result. Maybe my technique but i just find it better.
Reply to Tumbled travertine edges , best way ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
Hi guys, had some great advice here before so thought I would ask here for advice again...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
Tile Buying Popular Threads
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
