ryan2036
Newbie here and excuse if I sound too dumb.
I am planning for electric UFH in my new Kitchen that is now being installed. Floor currently is laminate floor but I found that it has small square tile under the laminate floor. What is the best way of laying UFH?
Options are:
- Can I use primer on the existing tile, 6mm insulation board (to cut cost), UFH and then new tile.
- Should I remove existing tile, level the floor and then insulation?
- I need to tile around 14 Sq m with heating area of 12 sq m. What UFH system (make/brand) should I use?
- 6mm board or 10mm board?
- I have a radiator in the kitchen which I am not planning to move hence UFH wont be a primary source of heat. So what wattage should I use? 100w/150w/200w?
- Mat or cable?
Will appreciate all reply with suggestions and recommendations.
Options are:
- Mat or cable?
