Stevoe
Hello experienced craftsmen, I need a little advice. I am in the process of building a bathroom which is constructed so far as follows. The floor is normal chipboard floor which has been overlaid with 18mm wbp ply screwed at 300mm or less centers, all walls within the shower area are Wedi on stud wall or lightweight block the shower base is a Wedi Fundo and all other walls are covered with Marmox 12.5 mm, all joints are sealed with Wedi tape, Bal single part flexi adhesive was used under and over the tape. As yet I have not treated the floor but planned to use Durabase uncoupling membrane stuck down with Bal single part flexible and water-resistant adhesive, then electrical UFH, then self levelling flexible screed then more Bal then 300x400 travatine tiles, two other walls have porcelain the shower tray will have travatine mosaics and the biggest wall with a big mirror on will be oyster coloured slate. The shower area will be almost enclosed on three sides with walls the last opening will have a 800mm glass screen leaving 500mm of opening to walk in and out of.
My question is do I put the UFH down first then self levelling screed then decoupling membrane or is it Durabase then UFH then screed, the adhesive instructions say sealing is in with the mix (I think) but dont expect the area outside of the shower to get that wet, so a further question at the back of my mind is should I also seal the WBP ply?
