H
Discuss UFH cant be turned on for a while ! in the UK Tiling Forum area at TilersForums.com.
Is the ufh within the screed or matting type..?
You need to find out as the in-screed type needs to be commissioned first..
What i mean is the ufh needs bringing upto temp and cooled again before you can tile that screed...and how deep is the screed..prob not dry enough yet..
If you commision the heat before the screed is cured, you run a very real risk of a tile installation failure
You MUST commission the ufh first before tiling....
The screed needs to expand and contract before applying tiles.....Me personally i would be using an un-coupling membrane with stone on a heated screed...but that's the way i work..
Thanks for your post doug - so how long would you give a 3" concrete screed to cure (naturaly before tiling with no UFH)? and if I do tile (I would prefer to wait longer but the cleint is aware or the risk and is happy to go ahead and tile)should I just leave the heating off let the concrete dry naturaly under the layed stone and then turn the UFH on slowly at a later date ?
He won't be if it goes belly up and it will be you that gets a phone call
Reply to UFH cant be turned on for a while ! in the UK Tiling Forum area at TilersForums.com
