brownjoe
Hi All
Firstly thanks for all the info / help and interest in this - didn't imagine the forum could be this helpful.
I don't have any other pictures unfortunately - but here's all the other info i have.
To put it in context - i've had the dining room and lounge knocked through and added a conservatory - there is underfloor heating in all three areas - and not one of the areas works properly - each area is a separate zone with a separate thermostat - the biggest area is no more than 3.5sq metres (the area in the picture relates to the dining room).
The heating does not extend under the units, and the builder who laid the floor also did the tiling.
I believe the chip board you see in the picture is the only floor surface - i.e. it is not laid on top of another floor surface - that is, it's laid on top of the floor boards. But i can't be certain of this.
I have access to the basement below the floor and can feel the ceiling is as warm as the tiles above.
I don't think the problem is with the thermostat regulator turning the temp off at 22 degrees as I'm pretty sure i have over ridden that. Also, in the conservatory the thermostat gets to about 24degrees but the tiles are actually cooler than in the dining room / kitchen.
i has underfloor heating fitted in my bathroom about two years ago (different builder) and i recall they put some sort of foil down first - which i guess insulated the floor. But obviously nothing like this was used this time.
An electritian did check all the zones were working properly and their is power to the system and the tiles do heat up a bit when switched on. But basically it has to be on full power constantly just to take the chill of the tiles.
The electritian did speak to the manufacturer - the manufacturers response was that it must be the insulation (lack of) for it to be happening not once but three times. Would welcome any further help / suggestions / possibl solutions.
thanks all
Joe
The system used is a Raychem wire UFH unit.
thanks all
Joe
