Discuss UFH/ floor tileing in the British & UK Tiling Forum area at TilersForums.com.
johnatjdl
Hello guys, my first post but I havnt had much time to navigate it yet, so hopefully this is in the right section. If somebody could give me some advice on the following I would be very gratefull.
I am a qualified plumbing and heating engineer with loads of tileing experience.
This is a project at home (bungalow with access under the floor, suspended timber floor,400mm joist centers)
- Spliting a big bathroom in toTwo. One an ensuite/wetroom, one stays as main bathroom.Both to be tiled and UFH in both. Using spreader plates, kingspan type insulation underneath.
Currently 22mm chipboard, obviously going in the skip, what type of flooring should I use that will take a tanking membrane and tiles, I am tempted to screw down 20mm ish marine ply or far eastern ply and tile straight on top. What do you guys think ?
Regards John
Rich
Min of 15mm ply (18mm is easier to get your hands on), seal the underside and edges, screw down at a min of 300mm centers, stager the boards and leave a 2-3mm joint between each board. Then over board with a 6mm cement board, screwed and glued.
Sounds like a lot of work but it is the best way to make those floors last. Have a read through the link below for a little more info on tiling directly onto ply
Plywood floors...
Reply to UFH/ floor tileing in the British & UK Tiling Forum area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
Morning all, I have been given the opportunity to quote for a 110m floor in a chevron pattern...
UFH/ floor tileing
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
