Discuss UFH Heat problem with marble floor in the British & UK Tiling Forum area at TilersForums.com.
PHG Dave
Due to the relatively thin 8mm tiles the floor has very little thermal mass to enable it to absorb the heat from the UFH and then slowly release it.
You don't mention the wattage per square metre that your setting is giving you but it sounds like it is too low if the tiles are dissipating the heat quicker than you can put it in.
Are you sure both kits are working?
U
Uheat - Keith
To check what your wattage is, per square metre, you will need to find out a few things.
a) What is the wattage per metre? b) What is the length of the loose cable? c) What is the total wattage per each length of cable? d) What is the free floor area in square metres, that the loose wire was installed onto?
"a) x b) = c)" "d) :- b) = w/m2.
For installing onto an insulation board, a 10w/m loose cable, for installing under tiles etc, should has a spacing between 50mm and 70mm. Not forgetting you have two cables.
This should then give you an approximate watts per metre square of between 125w/m2 to 175w/m2.
Reply to UFH Heat problem with marble floor in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
