Discuss UFH & insulation boards in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Sean...
Insulation boards are there so that you do not have to heat the whole slab....
If you have to heat the slab first then the heat transference will take ages and the running costs will be awsome..
By using insulation boards the heat goes no further than them( depending on thickness used) and then the transference of heat is a lot lot quicker and the running costs are cut dramatically as well.
The thicker the insulation the quicker the transfer time within reason and the cheaper running costs....
10mm minimum should be used IMO..
yes, but wouldn't this act like a big (huge) storage heater... ie it would also take longer to cool down after the heat was switched off?
I've fitted lots of these kits before, some with, some without boards but it's difficult to compare running costs. Obviously all the manufacturers talk about warm up times to make their products sound more efficient, the retailers talk about ..... but ultimately boost sales.
I get it that where any kind of void is concerned its a definite "no brainer", but can you see my point with this...... the big radiator may not be ideal, but is there actually anything wrong with it.... does it REALLY add to the running costs significantly or would it even itself out by having shorter "on" times?
As you can guess I was with this customer a fair while :lol:
Reply to UFH & insulation boards in the British & UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
Essex
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
