The dread strikes when the number of a customer appears on your phone several months after you have done work for them.
This happened to me yesterday when a customer stated that her UFH is now blowing the fuses in her house.
I completed the job in May’14 and had a continuity test running on the mat from start to completion of job. I also took resistance readings before/during/after installation. These readings matched the mats documentation. I left the readings for the electrician. The usual spiel about turning it on gradually etc was given to the customer.
To be fair, the customer was ringing me for the name & number of the mats makers.
The mat was stuck to 18mm ply, then SLC, then 60x60 porcs in the kitchen.
Just by chance, the electrician was there and he stated that the continuity test was fine, but when he put a high volt through the cable it showed a possible crack in the insulation.
I’m not a sparky, but what else can I do at installation stage when all the readings are fine.
I believe that they tested the mat in May and it was fine.
Strangely enough their previous ufh mat did the same thing. It was down for 5 years then developed a fault where it kept blowing the fuse – possible connection?
Has anyone else come across this scenario?
