Discuss ufh on wet room floor? in the UK Tiling Forum area at TilersForums.com.
Mike
do you guys recommend running the ufh onto the wet room floor? i don't plan on doing it but just wondered what your thoughts are. at the moment the tray is flush with the cement boards but with the ufh and slc on the main floor and 3mm difference between floor tiles and wetroom mosaics there looks like there'll be a step of 8mm or so going into the tray. i guess i'll just have to 'form' the tray using spf? i'll do it in 2 coats. any other suggestions? i don't know what make tray it is, this job's for homebase and their plumber fitted it, it's blue, looks plastic and is screwed straight through into the floor. cheers
Mike
Hi Mike... I was in the same predicament as you. I had a step and was going to put UFH on to the tray...
decided against it and feathered the edges (not the whole tray)
yeah i'll prob doing the same dave but i want to get the tray right before i try lay the mosaics. did your mosaics work out okay on the tray without 'enveloping' ? as the mosaics look the same size as mine, 40mm or so
Stewart
I do it all the time with the Marmox Showerlay trays.....
I nomally install tray, then 10mm Marmox to the rest of the floor.
I then install the heatmat on the floor and the former. I then SPF over the cables on the former and slc the rest of the floor.
After that, I then install "Homelux Floor" to tank it and to work as a decoupler.
Once this is done, I then tile as normal. I've done it this way dozens of times with no problems and works well for me. I also think all wet floors should be heated as the dry out much quicker.
Created on iPhone.....
Mike
The way i got round this was to step back the main tiles from the edge of the tray and build up with some rapid adhesive so there was no lip between the two different tiles, if you see what I mean..or have I got the wrong end of the stick..
i think i know what you mean but i'll be increasing the size of the shower area then slightly, but i can't see that being a problem
Reply to ufh on wet room floor? in the UK Tiling Forum area at TilersForums.com
6K
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
Hi all, I'm new to the forum and after your advice and collective knowledge please? I am in the...
10K
WetSaw
F
Good evening all. I need to tile the kitchen floor over the bank holiday weekend. We are having...
12K
Futuregrout
F
TF Group Please Join
Tilers Forums on FB
