Daveyboy
Hi guys...went to look at a job today, house refurb/extension..100m2 of 600x400 limestone tiles on solid floor over seven joining rooms (ground floor) and three ensuites with chipboard flooring (first floor)..Normally, I would lay 12mm plywood onto the ensuite floors (approx 3.5m2 each) then tile onto that but in this case I can't because the height change hasn't been allowed for and because the previous tiler who has been sacked (they call him lippy for obvious reasons) has already tiled the bathroom...it looks like he has tiled straight onto the chipboard but the main builder assures the client he primed the chipboard then laid a matting down then tiled onto that...
I've used the impey membrane and the dura WP matting before but never directly onto chipboard...
Is the impey membrane suitable to apply directly onto chipboard after it has been primed?
Is dura WP suitable given the small areas and if so, what flexi adhesive is suitable to use on chipboard?
Is there another product(s) I should use?
The client looks worn out from the building work and stress from the previous tilers' work, and I'd rather not add to it by using the wrong material.
