Discuss Underfloor heating - Tile marks - Help! in the UK Tiling Forum area at TilersForums.com.
DHTiling
Scary. Would the ribs have been noticeable if the tiler had used white addy? Or should he have checked his tiles to make sure he was getting full coverage maybe? I just want to make sure i don't end up footing the bill for this sort of ****up in the future!
White or grey, it's the moisture that has bled and stained....if you back skim then the colour change is fully uniform....
DHTiling
I back skim all floor tiling and the majority of wall tiling as :
1: it prevents shadowing on light bodied tiles etc
2: it creates a very good bond with the tile bed.
This is just my technique and works extremely well....Also if your tiles have profiled backs it deffo gives a better bond..
Back skimming is not to be confused with back buttering...
Back skiming is using the flat side of the trowel and put adhesive onto the back of the tile and scrape it back off again leaving a very fine skim on the back and back buttering is applying adhesive either with the notched side of the trowel or using a margin trowel and spreading the back for build up etc....
Dan
Admin
Staff member
5,091
1,323
Staffordshire, UK
Notice poo-hot advice when you see it people!
K
kohini
Hi all,
Still trying to sort this out. Found some left over adhesive and it is called 'Bond It Rapid Flex - Grey part flexible floor tile adhesive' Not sure if this was used in the underfloor heating part of the job.
Is this the correct adhesive? Although it seems like from the recent comments it's just to do with the amount of adhesive irrespective of colour...
One question, if sufficient adhesive was used, will it bleed evenly, making the whole tile darker (instead of ribbed). And will the bleeding only occur on underfloor heating only?
Thanks for your support...
K
kohini
Hi Dave, many thanks for your advice.
I am still trying to get my head round this....How would you apply the tiling in my situation?
I have underfloor heating in half the room. The entire room is tiled. If the tile bleeding only occurs in the half of the room (the part with underfloor heating) and we apply sufficent adhesive, then we would get half a room darker (albiet evenly) than the other. Am I right in my assumption?
How would you apply in each half of the room? Type/colour adhesive and application method in each half to ensure even colout throughout?
Thanks again
DHTiling
I have just looked at the pic again and that is deffo adhesive ribbing....But for it to happen only in the ufh bit is very strange....it's as if the ufh could have caused the adhesive to reacte.....I think a call to the adhesive manufactuer is needed to see if it is suitable for the job in hand then take it from there....
I also think it might be wise to pop a tile up and see exactly wot is going on under the tile...
You will not damage the ufh as it is within the screed as long as you do not over impact the floor when trying to get a tile up...
It has got to be the ufh causing the adhesive ribs to show but why...first on me this one..?
bootsmckiber
Definatly used the wrong addy,I always use white addy when using light tiles for the extra few dollars for a 50lb bag(which the customer pays for anyways)always flat trowel the back,that usually stops anything that might cause discolorment from soaking into the tile.Good luck on that one,it ****es me off when people call themselves tilers and go in and do somthing you could find in a tiling for dummies book,it makes legitimate tilers look bad,I truly hope you have the time and money to take the hack to court,especially on heat,costs a few bucks(quid).
Mike :mad2:
basshunter
"Different manufacturers work to different standards to meet varying market conditions and requirements.The blueprint is not always adhered to as strictly in quality control and selection of 1st choice materials as in the past..."Porcelain" no longer guarantees a product that complies with the original standards.Therefore,installation methods,care and maintenance considerations,and performance expectations vary."
You may be pleased to know a quick google showed this:
KENORA POLISHED PORCELAIN 40X40CM BARGAIN £6.00m2 on eBay, also, Tiles, Bathroom, Home Garden (end time 26-Apr-09 13:02:41 BST)
Reply to Underfloor heating - Tile marks - Help! in the UK Tiling Forum area at TilersForums.com
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
