Discuss underfloor heating in the British & UK Tiling Forum area at TilersForums.com.
abskiing
If you are using UFH on concrete you must use an insulation board fixed with a 1 part flexi cement otherwise the heat will transfer into the floor faster than it will heat up the tiles. Then tape your cable/matting over this and fix the tiles using 1 part flexi cement.
Terminate the cable at a suitable site where the thermostat control is to be sited. The electrical connection to this must be made by a qualified electrician. it is usually via a fused spur which is connected via a 30ma RCD on the circuit.
hope this helps
abskiing
Reply to underfloor heating in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Hi all, Was looking for some advice in regards to micro-cracks appearing on the SLC on top of...
underfloor heating
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
