Discuss underflor heating mat or wire? in the British & UK Tiling Forum area at TilersForums.com.
jimshell
hi can anyone help am doing my kitchen in a couple of weeks and am looking at warming the floor coz god it is cold in there(no heating in kitchen) am going to use plinth heater but am also getting underfloor heating which is best? would i need insulation on floor (concrete) bungalow built in 1971. also fitting mdf splashbacks to walls what is best stuff to adheer to walls many thanks jim
Dave Carr
Have you thought of using enerfoil? broken link removed
Very thin (1mm) and really easy to install, so the floor height hardly increases. You can install it straight to the concrete assuming it's smooth floated not rough. Then use a flexible adhesive and grout for the tiles.
I always do the whole floor that ways there's no cold spots and actually works out cheaper to run, because of the lack of cold spots to draw the heat back down.
Here's how to install
Link removed
grumpygrouter
Have you thought of using enerfoil? Broken Link Removed
broken link removed
Interesting concept. I notice you say it can be applied straight to a concrete base. Does this not pose the same cost problems as wire/matting applied straight to concrete as you are heating the slab?
Grumpy
Reply to underflor heating mat or wire? in the British & UK Tiling Forum area at TilersForums.com
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
Tiling a new extension. Cement poured screed on piped underfloor heating. Heating has been...
hi all i having my bathroom flooring installed with 18mm ply over the entire floor joists then...
Need some help please with calculating levels and the build up of the floor to support tiling...
7K
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
