Discuss Undertile heating under 18mm marine ply, with travertine tiles in the British & UK Tiling Forum area at TilersForums.com.
Hi advice needed before attempting floor. Wet Ufh being installed and current chipboard being cut out in places to allow pipe to be layed. Pipes will be inbetween joists therefore no room for noggings to be inserted, so to ensur strong deflection free floor and am not wanting to take risks. I plan to relay chipborad thats been removed and screw to joists as its T&G, then lay 18mm wbp ply with 2mm expansion gaps between boards and on top lay dural ci+ decoupler membrane. Fix mat and tile using Spf.
I realise it wont be the most efficiant ufh system but heat will still get trough it, I just think its prob the safest way to ensure stong stable floor for soft travertine tile.
All comments/advice will be greatly recieve.Thanks again guys.
Yeah its like you said defo not my first choice or ideal. The floor flles solid just chipboard but with the chipboard being cut for piping I think the safest plan would be to add correct thickness and type of ply along with a decoupler to ensure the risk of travertine cracking etc is mimimised but is there are other ways im not aware of im open to suggestions:thumbsup:.
Not done alot of Travertine work so want to cover all the bases, just wondering if the steps listed appropriate for the conditions.
Thought about that and suggested it but joiner wasnt happy laying ply onto joists without additional noggins, which he cant do due to the ufh pipe and screed etc. Therefore I thought 22mm chipboard with 18mm ply overboard to ensure floor is solid after all chipboard will have been cut in sections for ufh install then membrane to allow lateral movement and expansion. Finally tile using keraflex SPF.
100% dont want any issues with floor it be a nightmare.
Reply to Undertile heating under 18mm marine ply, with travertine tiles in the British & UK Tiling Forum area at TilersForums.com
gamer1
Hello Folks, I need to sort my floor out before I can lay tiles on it so seeking advice from...
Hello Everyone, I am new to this forum and I'm looking for your experts' advice in a situation...
Hello we are currently trying to choose a tile to lay on the ground floor (70m2) of our house...
Scotland
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
