Discuss Uneven Walls! in the British & UK Tiling Forum area at TilersForums.com.
Woody123
I know this has probably been done to death but, how do you decide if a wall is to bad to work with so you have to reboard it? I have read a thread on here where they have said they have filled in bowes in the wall that were roughly an inch!!! If you use a straight edge and some rapid set is there a maximum depth of what you can fill it in by? Or would such bowes in the wall have to be built up in stages?
Also if you do have to resort to reboarding then whats the quickest method of getting plaster down to the bare brick? Is it the auld trusty hammer and chisel or do you guys you other methods?
DEN
i would plaster walls with rapid set (all the low points) then use a 1800 feather edge from the bottom of the wall and pull it horizontally up the wall, this will shave off all the high points of f your rapid set. It doesnt need to be perfect as long as it is reasonably straight.If the walls were really bad and unworkable you will have to reboard,but if its just minor then as above.You can build the rapidset up in levels which cures in 3 hours,but you need to work fast as you only have 20 mins working time.
tysfoot
I have the same problem, i want to board the walla but cant cos the bath taps are to close to the wall.
Ive been told to bond it. should tak 4 hours to dry.
What exactly is Rapid set and where can you buy it from. is it like adhesive
The wall i want to do dips and comes out and i dont know what to do. I was thinking of hacking of the high bits and bonding the lows.
How is this done ?
Woody123
Cheers Den. Will follow that advice when needed.:thumbsup: I take it i might still need to pack out abit if walls arn't perfect to avoid lipping or should this be enough to eliminate that problem? Or is it a case of trowell the wall up and see how they lie? Do you always use your spirit level on top of tiles to check against lipping?
Sorry for all the questions!
devonmark
How is this done ?
Hi Tys, rapid set is adhesive, the cement based powder...rapid set adhesive..you will get it from any of your tile shops, just need to decide what make to go with, Bal and Mapei are a suggestion..Mark.
Woody123
Ok thanks for the advice guys.
1 more question for you den! Bit off topic like!
I see your from the newcastle area. How you finding work at the minute? Are you busy or is it Slow? Im a newbie but doest seem to be that much work around at he min. Got 4 bathrooms and 2 kitchens lined up but im only doing it at weekends and they are for freinds and family
sibs
do B&Q sell rapidset.
This is for dave. never used rapidset before , ive been pretty lucky for walls in the past.
Not to sure about the priming. do you mean prime say 1sm of wall then put tiles on using rapidset then move on to the next part of the wall
Tysfoot I think he means skimming the wall with the rapidset and priming in between each layer of skim.... building up the layers until you have an even wall. Rapidset is used because its fast drying time compared to a plaster skim and the primer is used to prevent the risk of a chemical reaction between the gypsum and the cement in the adhesive.
DEN
My first job will be to tile a toilet,in a few weeks time,haven't really started yet,just sorting out my business plan first.Know a few other tradesmen so will get work in no problem,its a bit difficult with trying to work around my current job at the moment,but as soon as i get regular work,then will go self employed,but just stick at it for now,you have to go and get the work,it won't come to you,and sell yourself to the customer whenever you do a aquote.You will get your reward soon enuff.
Best of luck..
DEN
Woody123
yeah im gonna try and get out there as much as i can and juggle round my current job then if i build up work maybe go part time at work and tiling the rest of the time until i eventually have enough work to go full-time. Anyway thanx for the good advice and good luck for your tling too!!
p.s if you get toooo much work you can always pass some on to me!! :lol:
Reply to Uneven Walls! in the British & UK Tiling Forum area at TilersForums.com
Hello! I’m hoping I can get some advice on what to do in my kitchen RE wanting to replace the...
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
5K
Uneven Walls!
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
