Discuss Unsuitable walls in the Canada Tile Advice area at TilersForums.com.
Rickm34
Hi there. So i have a job coming up. 5 fully tiled bathrooms. Glazed Porcelain tiles 300 x 600. First bathroom is 'ready'. Went to price it up. Tiles are a discount lot. 2 batch numbers which isnt a problem, but no box weight. So 2 walls in the first bathroom are skimmed plaster on pb. ( in my opinion tiles way too heavy for skim)I manage to stop them doing anymore. The remaining walls are bare pb, and bare pb in the other bathrooms.
Im using tilemaster extrabond standard set on walls
And tilemaster setaflex rapid on floors
Tilmaster grout 3000 grey flexi
And tilemaster prime plus
So i informed the builder who was oblivious to weight issue, and said it will be reet tiles wont fall off.
Im not happy about the 2 walls but he is adamant it will be fine.
I was planning on producing a waiver that the builder could sign that i have informed him of weight issues but that the builder is happy to proceed. How much weight will this hold, if you excuse the pun.
Anyone every done something like this?
Also in regards to the primer would you prime the plaster skim?
L
LM
Skimmed plaster can only hold 20kg per square metre, it's one of the worst substrates to tile on and yes it must be primed with two coats of an acrylic primer, never ever use PVA.
Plasterboard can take 32kg per metre squared, also prime.
Would it be possible to over board the skimwd walls with some mechanically fixed backer board or at worst plasterboard?
The waiver wouldn't be worth the paper it's written on here, fundamentally you are responsible because you know you should not be tiling on a substrate that can't take the weight. You'd loose in court.
Rickm34
Thanks for your reply. This could be one method as it is just at a shell stage. Or they might have to reboard the original. As the waiver is useless i wont be tiling it until its right.
In regards to the primer, im using the tilemaster prime, as i like to use all the same product. I never used wood glue.
The tiles will weigh approx 24kg per m2
Adhesive has an average weight of 1.5-2kg per mm per m2
As a 10mm trowel will give approximately a 3mm solid bed, this equates to somewhere between 4.5-6kg per m2 depending adhesive.
So you would be looking at a combined weight of approximately 28.5 - 30kg per m2.
This is for guidance only, but should be somewhere near the mark.
Rickm34
Ok cheers i will bare that in mind. Might just take the bathroom scales lol
Reply to Unsuitable walls in the Canada Tile Advice area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
What would you guys do with the walls to prep for fitting 1200mm x 600mm Onice Verde (Porcelain)...
Unsuitable walls
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
