Guest viewing is limited
Tiling Tool Suppliers
Discuss Using a wetsaw TILE CUTTER in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
H
hooly
Any tips, as in whats the right way, I go in, cut tile, then come back out, trying not to clip the blade, if its not a full peice
Do you do hand either side, and follow right the way, I tend to clip the corner? sotry to hold from just the one side
I need 3 slivers, inch,
do you check blade for tightness time to time, does it just feel diff when blade is getting blunt?
cheers, first time user of one
Gazzer
It takes time to find what works best for you and the particular cutter, same with hand cutters. Call it technique.
As you use the machine you may not notice the wheel losing its edge as it will be gradual, but when you replace the wheel WHAT A DIFFERENCE !.
Different wheels cut better than others, names to look for are Rubi CPC, Marcrist, Beava and Norton.
As for holding the tile then what ever you feel comfortable with.
As for the corner clipping i would say the wheel is past its best or of cheap make, or maybe you are pushing through too hard. Wheels that are out of balance can cause the tile to vibrate and that too can make the corner break off.
Reply to Using a wetsaw TILE CUTTER in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi everyone. Tiling my bathroom first time and going well so far! 600x300 ceramics on walls and...
Hello, I am looking at getting a sigma. I am contemplating between the sigma ceramic cutter...
  • Sticky
Popular Tile Cutter Threads
    Votes: 5 5.8%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 22 25.6%
    Votes: 13 15.1%
    Votes: 26 30.2%
    Votes: 3 3.5%
    Votes: 2 2.3%
    Votes: 18 20.9%
    Votes: 14 16.3%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 3 3.5%
