I
iaincameron
Hi All,
I am now planning on using Mapei adhesive for my upcoming bathroom tiling. I am using 600x300 porcelain tiles on walss and floor with UFH fitted. I have reboarded most of the old plaster board on the walls and used Aqua Panel where the shower will go. In addition one wall is now 18mm ply. The floor has been overboarded with 12mm ply.
Can I use KeraFlex adhesive on the ply? Or should I use a different adhesive there? I don't want to use KeraQuick as I have no need to rush, in fact I would prefer the longer pot life. I will use Primer G for the plasterboard, but no primer on the aqua panel. What about the ply?
Finally, can you get Ultracolur plus grout in different colours? only have two or three colours and I need it in brown for the floor and white or beige for the walls.
Cheers
Iain
Cheers
Iain
